Où trouver encore le firmware 3.4 pour Rev/Board 64 ?
Messagepar llooping » Mar 6 Fév 2018 16:02
Est-ce quelqu'un aurait de dispo la MAJ en 3.4 SVP ?
Mon robot :
XV 15
Board 64
SW 3.2
llooping
Re: Où trouver encore le firmware 3.4 pour Rev/Board 64 ?
Messagepar glnc222 » Mar 6 Fév 2018 18:53
The Rev64 Binky system board firmware files were captured in Russia, for the Neato Robotics updater program installed in the USB driver download.
http://www.robotreviews.com/chat/viewtopic.php?p=127302#p127302
Files for the Cruz Rev113 older system board were captured for the Vorwerk updater program. See the other links posted here.
Read the rest of the thread linked above for details of the updating operation. There are no important changes from 3.2 to 3.4 in my opinion. Minor tweaks.
The updater program is a script driven terminal emulator with scripts to perform the update with text commands, referencing files, some time delays and things.
Everything must be correct and I think the bot must be on battery power off the dock when updating, because the power management software is being updated.
Any problems can damage the system beyond repair because the update is actually performed by the robot itself.
Also check the Vorwerk material for Rev64 if included.
Messagepar llooping » Mar 6 Fév 2018 19:04
Ok thanks.
I will try :)
CY
llooping
Messagepar MrGreen » Ven 13 Avr 2018 07:16
llooping a écrit:Ok thanks.
I will try :)
CY
Salut, il fait quoi ce firmware en fait et il est pour quel machine ?
Proscenic 790T (8/10)
Botvac D85 (8.5/10)
Kobold VR200 (9/10)
Braava 380 (7/10)
Roomba 531 (5.5/10)
MrGreen
Messagepar glnc222 » Sam 14 Avr 2018 14:50
The Russian files with link prior post are for the Neato XV with Rev64 Binky system board. However, with Rev64 Vorwerk VR100 and Neato XV share the same firmware, with an unpublished USB command SetConfig to enable different features in the two products, e.g. battery type and side brush.
Another set of files is supplied to use the Vorwerk updater program on XV models, first switching them over to a Vorwerk setting. These files may also cover the older Rev113 Cruz board as well. Not all the SetConfig commands work on that older board. http://www.robotreviews.com/chat/viewtopic.php?f=20&t=19005
Messagepar Spary » Mer 12 Juin 2019 11:11
Je recherche le firmware 3.4 pour mon mettre à jours mon neato xv (board rev 64).
Le lien de téléchargement que glnc222 a donné est mort
Est-ce que quelqu'un aurait sauvegardé ce firmware et pourrait le partager ?
Spary
Messagepar glnc222 » Dim 16 Juin 2019 13:57
Additional firmware file links from Russia
System board Rev64 Binky v3.4 https://yadi.sk/d/O3xXQ8t_NLw9lA
v3.0 or 3.1, not clear which is which
https://yadi.sk/d/8gRMOkuG0cfbKw
https://yadi.sk/d/BniHBCs2u_SYTA
Do not use with Rev113 Cruz system board with different processor.
These code files are to be referenced in the scripts for the Neato updating program included in the USB driver package as described at
Messagepar glnc222 » Sam 6 Juil 2019 15:33
The download link for v3.4, Rev64 Binky system board above works July 6, 2019. Click on the small download arrow in the Russian web page opened.
For using this file see procedure at http://www.robotreviews.com/chat/viewtopic.php?p=138561#p138561
For the USB driver and updater program files needed see http://www.robotreviews.com/chat/viewtopic.php?p=127716#p127716
Messagepar fat » Sam 30 Mai 2020 01:21
Bonjour, le firmware 3.4 est il si bien que ça par rapport à un firmware en 2.6 sur un Neato XV-14 ?
fat
