Choix pour un nouveau robot
Messagepar Kek-de-Mars » Sam 27 Juil 2019 07:20
J'avais un neato XV-15 depuis 6 ans mais là, entre des problèmes de charge et un écran blanc que je n'arrive pas à réparer, j'envisage d'en acheter un neuf. Auriez-vous des conseils? Je pars pour reprendre un neato, à moins que certains me le déconseille fortement. Après c'est question de budget. D3, D4 (quelles différences?), D5 avec brosse latérale?
La brosse latérale sur les neato amène-t-elle un avantage réel dans le nettoyage des bordures?
Merci d'avance.
Kek-de-Mars
Re: Choix pour un nouveau robot
Messagepar Kek-de-Mars » Lun 29 Juil 2019 06:45
Personne pour un petit conseil d'achat?
Kek-de-Mars
Messagepar glnc222 » Lun 29 Juil 2019 19:57
After using a Roomba and then both a Neato XV and later a Botvac, I replaced them with a Samsung Powerbot. I just find too many defects and repairs made to Neato electronics, while Samsung has a reputation to protect being a major electronics supplier, and also supplying many of the components for the assembled products. I also like the washable filters and have never had to buy any filters after several years use. I still have not touched the second extra filter supplied with the particular unit.
Repairing Neato's may be entertaining for hobbyists, but not what I wanted in a consumer item. Originally, the Powerbot's were much more expensive, but have become competitive over years, especially with the small 7000 series models.
Neato's original lidar guidance was a good advance over the random navigation in Roomba's, but is now very old and superseded by solid state camera robot vision guidance, without moving parts which wear out. Repairing Neato's is also made worse by lack of spare parts supply direct from the company.
The one feature Neato supplies which has not yet been duplicated by competition is the virtual boundary marking or no-go lines which can be entered on a graphic computer display, without physical barriers such as the magnetic strips originally used. I still use those strips with the Powerbot.
Messagepar Cédric » Lun 29 Juil 2019 20:15
je te conseil de jeter un oeil à mon classement : https://www.kelrobot.fr/classement-general/
Messagepar glnc222 » Lun 29 Juil 2019 20:32
Ranking omits Powerbot 7060, at 806 Euro in France. The 9350 ranked is a much larger than the other robots listed, Neato and Roomba etc., and not so comparable.
Messagepar Kek-de-Mars » Mar 30 Juil 2019 05:57
J'ai lu les test mais ça ne remplace pas le vécu à long terme. L'obsolescence programmée et les pannes qui arrivent quand la garantie n'est plus valable...
Personnellement je n'ai jamais trop été emmerdé par mon ancien neato. Mais quand ça a commencé au bout de 6 ans, je ne m'en suis jamais sorti. Après est-ce qu'on considère que 6 ans pour ce type d'appareil c'est déjà très bien ou qu'il doit durer plus longtemps...
Donc merci d'avance pour vos retour d'expérience comme celle de glnc222!
Kek-de-Mars
Messagepar Jean-benoit » Mar 30 Juil 2019 18:57
Un aspirateur robot reste un objet technologique plus ou moins complexe et qui reste très onéreux ! Qui aurait acheté il y a quelque années un aspirateur traineaux a 3000 ou 6000 francs !!! probablement personne.
Je partage le fait de dire que les Neato XV ont des problèmes congénitaux ( condensateur, diode, moteur ...)mais, qui restent toutefois réparables dans la plupart des cas (absence de composants discrets par exemple...) même si il n'existe que très peu de pièce de rechange officielle.
Les premiers botvac ont également aussi des soucis de fiabilité.(pare choc, roulement, encrassement....)
Un gage de longévité est bien évidement l'entretien, un petit de coup de soufflette de temps en temps ne leur fait pas de mal.. Pour moi les XV comme les VR100 sont très robustes et, suffisamment performants.
Messagepar Kek-de-Mars » Mer 31 Juil 2019 05:40
Merci pour cet avis. Mon 15 étant mort et n'étant plus produit, faut bien que je me rabatte sur un autre... A moins d'acheter un signature d'occase sur le bon coin mais je suis pas très chaud de l'achat d'occase pour ce genre de matériel...
Kek-de-Mars
Messagepar Kek-de-Mars » Mer 31 Juil 2019 05:42
J'ai trouvé un Signature pour 100€ près de chez moi, mais avec les batteries HS...
Kek-de-Mars
Messagepar Kek-de-Mars » Mer 31 Juil 2019 17:05
Un signature pro 105 euros avec batterie fonctionnelles apparemment... Je me laisserai bien tenter. Un avis?
Kek-de-Mars
Messagepar Jean-benoit » Mer 31 Juil 2019 19:30
bonsoir
Oui !
il a beaucoup d'heures de vol ? dans quel état est-il ?
Messagepar Kek-de-Mars » Mer 31 Juil 2019 20:37
Le vendeur dit très bon état. Brosse et batteries changées en 2018. Après, je vérifie comment??
Kek-de-Mars
Messagepar Kek-de-Mars » Jeu 1 Aoû 2019 16:49
Alors je me laisse tenter?
Kek-de-Mars
Messagepar Cédric » Dim 4 Aoû 2019 20:56
Si tu te laisses tenter, demande à le voir fonctionner. Pour environ 200€ de plus tu peux trouver un robot neuf et performant
Messagepar Kek-de-Mars » Mar 6 Aoû 2019 17:55
J'ai franchi le pas. 105€ pour un signature pro d'occase. Les batteries tienne plus d'une heure le robot est en bon état général. A suivre donc...
Kek-de-Mars
Messagepar Kek-de-Mars » Sam 10 Aoû 2019 10:21
J'ai une version très vielle du firmware, genre 2.6. Je peux mettre la dernière, la 3.4? Et si oui comment parce que je n'ai trouvé nulle part des liens valables...
Kek-de-Mars
Messagepar Kek-de-Mars » Lun 12 Aoû 2019 13:00
Personne pour une info sur une mise à jour firmware?
Kek-de-Mars
Messagepar uranus-13 » Lun 12 Aoû 2019 15:30
[b][u]LIEN :[/u][/b]
[url]http://www.robotreviews.com/chat/viewtopic.php?p=127716#p127716[/url]
[url]https://www.kelrobot.fr/forum/ou-trouver-encore-le-firmware-3-4-pour-rev-board-64-t3948.html[/url]
[url]https://translate.google.fr/translate?hl=fr&sl=en&u=http://www.robotreviews.com/chat/viewtopic.php%3Ft%3D19005&prev=search[/url]
Messagepar Kek-de-Mars » Mar 13 Aoû 2019 12:49
Merci. J'ai récupéré un fichier : XV11App.Prod.Box.24079.enc
J'ai NeatoControl.
J'ai récupéré le programme KoboldVRUpdater_110_fr.
Après c'est un peu flou car je ne suis pas certain qu'on parle de la même chose.
J'ai ça sur mon signature pro récupéré d'occase:
Software,3,2,18755
LDS Software,V2.6.15295,0000000001,
LDS Serial,KSH52513AA-0213416,,
LDS CPU,F2802x/c001
J'ai donc un firmware 3.2 contrairement à ce que j'avais annoncé plus haut. 2.6 c'est le LDS software...
Ai-je récupéré les bon outils? Est-ce que ça vaut le coup d'avoir la version 3.4 du firmware? La manip n'est-elle pas risquée?
Merci d'avance.
Kek-de-Mars
Messagepar uranus-13 » Mar 13 Aoû 2019 13:19
[b][u]Extrait d'une discussion :[/u][/b]
[b]"
Re: Firmware 3.4 pour XV dispo !
Messagepar gom » Mer 8 Oct 2014 13:48
Je copie/colle ce que j'ai écrit en commentaire de la news du site :
Mon XV-15 était en version 3.2.18755 (Board Rev 64, LDS « vide » et Board SW 18077), il est maintenant en 3.4.24079 (Board Rev 64, LDS V2.6.15295 et Board SW 23179).
Mon XV-25 était aussi en version 3.2 (je n’ai pas noté le numéro complet), il est maintenant en 3.4.24079 (Board Rev 64, LDS V2.6.15295 et Board SW 23179).
Bref, c'est la même mise à jour pour mes 2 Neato.
J’ai remarqué sur le site Internet de Neato que le numéro de série de mes Neato était à renoter car ils ont changé la mise en forme des champs de saisie.
En avril 2014, j’avais noté le « - » dans le numéro de série, alors que maintenant il faut saisir les numéros avant et après le tiret codé en dur dans la page web dans des zones de texte séparées.
Peut-être est-ce uniquement ça votre problème de non proposition de la mise à jour : il faut ressaisir votre numéro de série selon le nouveau formalisme. "[/b]
[b]LIEN :[/b]
[url]https://www.kelrobot.fr/forum/firmware-t2822.html[/url]
Discussion intéressante. Vous trouverez certainement des informations et peut-être que quelqu'un qui a ce robot aspi et a fait la manip viendra vous aider.
Malheureusement je n'ai pas ce robot aspi. Voila si cela peut vous rendre service.
Là aussi, intéressant chez nos amis Américains :
[url]https://translate.google.com/translate?hl=fr&sl=en&u=http://www.robotreviews.com/chat/viewtopic.php%3Fp%3D134994&prev=search[/url]
[url]https://translate.googleusercontent.com/translate_c?depth=1&hl=fr&prev=search&rurl=translate.google.com&sl=en&sp=nmt4&u=http://www.robotreviews.com/chat/viewtopic.php%3Ff%3D20%26t%3D19005&xid=17259,15700021,15700186,15700191,15700256,15700259,15700262,15700265&usg=ALkJrhg443s3Pj12Hh99B80g9iPXT0mphg[/url]
