promo 735 euros samsung connecté SR20K9350W POWERBOT
Messagepar andre » Ven 16 Déc 2016 20:00
pour information le robot en tête du classement revient à 735 euros jusqu'au premier janvier 2017 :
promo à 885 euros chez Darty + 150 euros remboursés par Samsung après l'achat.
Je vous conseille de prendre l'extension de garantie de 3 ans de Darty avec remplacement par un neuf en cas de panne (je ne me souviens plus combien coûte l'extension) en tout cas moi c'est ce que j'avais fait il y a environ 6 mois (pour l'instant pas de panne).
andre
Re: promo 735 euros samsung connecté SR20K9350W POWERBOT
Messagepar Johnny 974 » Sam 17 Déc 2016 06:26
Quelqu'un pourrait me dire quel différence ya t'il entre le model 9350w et 9350wk mise à part le prix bien-sûr .
Johnny 974
Messagepar glnc222 » Sam 17 Déc 2016 18:36
"9350" is only part of the full model id, eg. SR20J9350U (or other letters). There is also an "SKU" id VR20J9350... on the bottom label.
Samsung delivers different models in different countries, for the power plugs at least. A model made for one country may not be warranted if imported into another country. The website may not accept registration, though registration there is for marketing information used by Samsung. Legally it is the sales receipt which matters for warranty service, not registration. I do not know that situation in Europe.
The internet app however, is a separate system with its own registration when setting up the app, and does not care which model it is.
All the 9350's are functionally the same. They have many different Powerbot models and packages, with some available only in certain countries.
It can help to check Samsung's own marketing website in your country for the models listed there.
When Samsung produced a previous model 9250 with WiFi in 2015, it was sold only in Switzerland in Europe, and no service was available outside that country. Of course customers in France and Germany nearby traveled there to buy some. Now a new updated 9250 without the mapping feature in 9350, is sold in the U.S.
Samsung has switched from optical, Virtual Wall boundary markers to mag strips similar to Neato. It is not known whether the new machines still respond to the IR boundary signals. Possible because the receiver on the robot is shared by the beacon in the dock and by the remote control. The technology is the same as used on TV remotes.
Messagepar Johnny 974 » Sam 17 Déc 2016 19:46
Merci pour ta réponse
Johnny 974
Messagepar skyjacks » Lun 19 Déc 2016 11:45
Même promotion chez Ubaldi où il est un peu moins cher.
skyjacks
Messagepar nanou29 » Mer 28 Déc 2016 17:06
Bonjour, une nouvelle version du samsung powerbot va etre présenté au mois de janvier 2017 à las Vegas.
Le powerbot Vr7000 Plus compact et 28% Plus fin mais toujours cyclonique.
Un peu déçu qu'il refasse encore une nouvelle version qui va coûter plus de 1000 euros à sa sortie pour à peine deux mois après etre bradé dans les magasins.
Je serais curieux du test de Cédric mais je ne craquerais pas une troisième fois pour un powerbot.
nanou29
Messagepar ramoss45 » Sam 9 Mar 2019 19:43
[quote="Johnny 974"]Bonjour
Quelqu'un pourrait me dire quel différence ya t'il entre le model 9350w et 9350wk mise à part le prix bien-sûr .[/quote]
[url=https://thegadgetwire.com/tencent-gaming-buddy/][color=#a9a9a9][size=33]https://www.oovoo.com/adam4adam/ [/size][/color][/url] [url=https://thegadgetwire.com/tutuapp/][color=#a9a9a9][size=22]https://thegadgetwire.com/tutuapp/[/size][/color][/url] [url=https://thegadgetwire.com/appvalley/][color=#a9a9a9][size=22]https://thegadgetwire.com/appvalley/[/size][/color][/url]
ramoss45
Messagepar glnc222 » Jeu 14 Mar 2019 03:16
I analyzed the old IR boundary when adding a mag strip sensor to an older 9250 not equipped for mag strips. See [url]http://www.robotreviews.com/chat/viewtopic.php?f=4&t=20181[/url]
A European owner was interested so we captured the IR signaling in use with old marker. They seemed poorly designed. A complicated exchange takes place where the boundary tower exchanges messages with the robot. The side proximity sensors on the robot also serve as IR signaling devices, being computer controlled instead of simple self-contained dedicated parts. These sensors also detect the IR spot projected on the floor with the remote for that follow-the-spot feature. Different coded messages allow identifying different components in the conversations with the robot.
Since the Virtual Wall IR tower detection is entirely in software, it is doubtful this code is continued in the models using mag strip detection.
A funny thing happened when analyzing the VW -- a peculiar software update occurred over the WiFi which changed the coding used in the IR signals, making the VW supplied with the robot unusable.
These Samsung VW's work entirely different from those by iRobot for Roomba robots. The Roomba VW projects a beam which acts like a wall, while the Samsung is an omnidirectional, 360 degree emitter which operates over a certain range in which it can be detected, and activated by receiving a coded signal from the robot's proximity detectors.
The Neato robots have gone beyond the mag strips to support "virtual boundaries" marked on a map of the floor in the smartphone app., with need for physical boundaries. It is not clear how well this works. Samsung has not yet matched this feature.
Incidentally, all the different brand robots with mag strip boundaries have the same detectors and work any brand boundary strip. Neato strips seem the best physically and have the widest availability. Such strips are more expensive than common magnetic stick-on material because they are magnetized in a different way for the detectors, with a single pole all across the top, compared to alternating poles in common materials.
Messagepar toche9595 » Mar 26 Mar 2019 19:42
Je l'ai vu pour beaucoup moins cher mais je ne me rappelle plus chez qui, si je retrouve le site je vais partager avec vous.
[color=#a9a9a9][size=75]_______________________________________________________[/size][/color]
toche9595
