XV-15 durée de nettoyage réduite
Re: XV-15 durée de nettoyage réduite
Messagepar uranus-13 » Lun 7 Oct 2019 19:12
[quote="Kek-de-Mars"]Merci mais quand je clique dessus j'ai une page blanche et ce message: Error 503 : Service Temporarily Unavailable
Ça vient de ma connexion, ma box, mes paramètres sécurité?[/quote]
Comme vous, "Error 503 : Service Temporarily Unavailable" ???
Messagepar glnc222 » Lun 7 Oct 2019 22:52
Repairing LCD by increasing the power supply voltage (without replacing the LCD)
[url]http://www.robotreviews.com/chat/viewtopic.php?p=148381#p148381[/url]
Messagepar glnc222 » Lun 7 Oct 2019 23:08
From time to time RobotReviews.com can be down for technical problems. It does not accept advertising. Devoted competent webmaster. It uses open source software similar to this site. Upgrades have often caused problems. It is working as of Oct. 7, 2019 at least. Just keep trying it over time.
(The German roboter-forum appears to use different software)
Messagepar Kek-de-Mars » Jeu 10 Oct 2019 17:03
J'y arrive jamais!!!!!!!!!! Toujours le même message d'erreur...
Si des gens y arrivent, peuvent-ils faire des copie d'écran? Ou c'est impossible sur ce forum?
Kek-de-Mars
Messagepar glnc222 » Ven 11 Oct 2019 03:16
Does the error message appear when accessing the home page robotreviews.com, or just the link above to a particular post on that forum?
What if you try the access from a different computer? Some of these systems have security features which are keyed to particular IP addresses which were found to cause problems in the past. A lot of spammers attack this forum, requiring a lot of work. One time we actually had a denizen of the Dark Web for criminals, trying to advertise stolen credit cards claiming expertise in theft. He was probably mislead by our forum labeled "hacking", which actually refers to robot hardware modifications in this context -- not so expert after all.
Messagepar Kek-de-Mars » Sam 16 Nov 2019 19:59
Me voilà de retour, malheureusement.
Encore planté et je pense à cause de la diode D14. Donc pas de charge...
J'ai un soucis avec la soudure je pense car je n'arrive pas à déposer proprement de l'étain sur le circuit imprimé. L'étain me reste sur le fer car on dirait qu'il y a un genre de cire qui empêche que ça colle... Vous avez un tuyau à me donner pour faire une soudure correcte?
Kek-de-Mars
Messagepar julla0 » Jeu 11 Aoû 2022 11:33
Je déterre ce vieux sujet.
Où se trouve ce capteur de mur?
julla0
Messagepar Jean-benoit » Mer 17 Aoû 2022 17:17
Bonjour Julla0
Le capteur de mur se trouve sur le coté droit du pare-choc .
Messagepar glnc222 » Dim 21 Aoû 2022 17:36
Sensor can be tested over USB with Neato Control for Windows, moving hand back and forth in front observing readings shown on PC.
Same part as the cliff sensors, but mounted differently, complete assemblies sometimes on ebay. Sharp proximity sensor.
Typical effect of defect is phantom wall detection causing robot to move in circles.
