Samsung POWERbot VR9000
Re: Samsung POWERbot VR9000
Messagepar glnc222 » Dim 19 Juin 2016 01:47
I will now be testing whether disabling the cliff sensors (covering with light colored tape, as done for black carpets), may correct some of the traps encountered against chair legs.
It will take some time because of infrequent encounters and difficulty reproducing precise collisions, will have to see about that. Over several weeks there would usually be some trap incident, so if none appear that would be an indication.
I have observed the Powerbot corner getting lifted against legs without getting trapped, so I theorize it is a combination of a wheel stall without bumper strike, with lifting the cliff sensor which triggers the oddly immediate shut down without more aggressive, corrective behavior.
Messagepar glnc222 » Mer 29 Juin 2016 16:51
Essential promo video [url]https://youtu.be/1ejY481L2sw[/url]
9350 promo video [url]https://youtu.be/oRT0OoUWeu4[/url]
Messagepar glnc222 » Sam 2 Juil 2016 18:40
Bumper extension made [url]http://www.robotreviews.com/chat/viewtopic.php?p=138379#p138379[/url]
Messagepar glnc222 » Jeu 14 Juil 2016 05:39
[b]Powerbot Side Bumper Extension Mod[/b]
An additional side bumper is added to prevent traps against furniture legs.
[url]http://www.robotreviews.com/chat/viewtopic.php?f=22&t=19388&p=138559#p138559[/url]
Messagepar cdasbc » Mer 10 Mai 2017 01:45
merci.
il est qd meme vachement haut :D
[url=http://www.coquegsm.com/category-coque-huawei-p10-78.html]coque huawei P10[/url]
cdasbc
Messagepar glnc222 » Mer 10 Mai 2017 02:14
Picture above omits vertical tape strips needed to hold the plastic in place; see the post at robotreviews.com for full details and more pictures.
The side bumper extension is for lamp bases. The furniture leg traps are due to the "wheelie" (motorcycles) problem fixed by limiting the wheel extension with cardboard in the wheel well. Same thread at robotreviews. When rubbing furniture legs the unit tilts up activating the sensor for picking up off the floor, shutting down. New units 9350 last year added counter weights in the front.
I do not understand the remark about it being high (haute), up away from the floor -- language issue? There is a separate problem with some robots where the bumper is too high off the floor, allowing the robot to climb on top of things which trap the robot. The Samsung bumper was low enough to engage the lamp bases except there was no bumper at all along the side; it swipes the side against things, turning. It is also possible to lower the edge of the bumper by attaching a plastic strip with foam mounting tape, but this did not seem necessary in my situation. (Plastic from wall corner guards in hardware store; bends into shape.) I also raised the base of one lamp on a finished wood disk cut to fit, decorative.
In other threads here the Neato robots are reported getting stuck on chrome bar stool pedestals. I tested this with the Samsung with no similar problem. The larger size may make the difference. Also Samsung has IR proximity sensors in the front. The sonar sensors in the Vorwerk VR200 version of Neato may work the same.
See the new 2017 Samsung 7000 series Powerbots for more improvements. Shutter over intake for corner cleaning, pet hair cutters on the brush guard. Not yet in Europe but it has just reached the U.S. It should be arriving in Europe soon. Check the Samsung website for your region.
Messagepar glnc222 » Mer 10 Mai 2017 23:23
[quote]il est qd meme vachement haut[/quote]
See 7000 new to fit under furniture. The bumper and wheels are also fixed on this new model.
Messagepar blackiyto » Mar 2 Avr 2019 22:02
merci.
il est qd meme vachement haut ...
blackiyto
Messagepar angella » Dim 2 Juin 2019 05:17
I had a robot vacuum cleaner for testing from Samsung. It was called Samsung POWERbot vr9000 and it cleaned fairly nice although you do need additional device for tight spots.
angella
Messagepar smithclarkson001 » Dim 3 Nov 2019 02:20
very powerful device indeed!!!
[size=02][url=https://redtube.vin/]Redtube.vin[/url][/size]
smithclarkson001
